GENX: Morphs should be in the morph folder for the according figure ?
Hello. I bought GEN X and gen2 et Gen3 add ons. There are three sections: transfer, presets and Morphs. I first load a V4.2 in the Tranfer section. Then I load a character (let's say MRL Ariana). I do drag and drop the PZ2 files (body and Head) in the tranfer section. No problem. Then Transfer. At this point, GenX says: Morphs should be in the morph folder for the according figure. Continue anyway ? At this stage, I don't understand what action is needed. I can't drop the pz2 files in the morph section Can somebody help me on this problem ? Any help will be appreciated.
Ichtos
You must first create a new .cr2 figure in DAZ Studio by loading V4.2 and then applying the MRL Ariana character. You then export the result (either as a full body morph, a head morph, or a body morph) and save it as a .cr2 with an appropriate name into a folder under the runtime folder in your content library (best is runtime/libraries/character/GenX). You'll need to create the last folder in advance or one of a name of your choosing. It is this .cr2 file that you enter under the Transfer tab in the Load Figure dialogue.
You should read through and follow the following tutorial:
http://www.sharecg.com/v/82453/browse/3/PDF-Tutorial/GenX-Plugin-Tutorial
It is slightly out of date as it was done before the release of the GenX for G3F addon, but the procedure is essentially the same.
