Script to Switch viewport to Default Camera?
SasqwachSasqwach Posts: 25
I frequently like to switch between the top, back and perspective views in Daz while working on my main camera angle, tho while it is handy to have shortcuts for views I would like to make a small script that would find the "Default Camera" in scene and switch to it immediately.
Have tried tinkering with Mcj's scripts to "find and select a camera" but not switch view to that camera
var vmgr = MainWindow.getViewportMgr();
var vport = vmgr.getActiveViewport().get3DViewport();
var cam = vport.getCamera();
if( Scene.findNode( cam.name ) ) //must be in the scene
Scene.selectAllNodes( false );
cam.select( true ); //selects but doesnt switch
cam......Switch to selected cam in viewport HERE!?
Sorry incredibly amatuer question but been looking thru the Api and can seem to find means to "switch" viewport to the selected camera via script.
Any ideas ?
Post edited by Sasqwach on
  • vport.setCamera( cam );
  • Thanks!  tho doesnt seem to do quite what I was expecting, selects the camera but still wont switch to the Default Camera if I am in any other viewpoert mode ie Perspective, Front, etc
  • hmm, not sure why
  • Richard HaseltineRichard Haseltine Posts: 111,310
    edited January 2017
    This works, except for the UV view (which I suspect is because it isn't a 3d view no, it doesn't fail at getting the 3D Viewport so I'm not quite sure what it is tripping on):
    // try to get the Default Cameravar cam = Scene.findNodeByLabel( "Default Camera" );if ( cam ) {	// work our way down to the 3D viewport	var vwmgr = MainWindow.getViewportMgr();	if ( vwmgr ) {		var vwport = vwmgr.getActiveViewport();		if ( vwport ) {			var tdvwport = vwport.get3DViewport();			if ( tdvwport ) {				// make the Default Camera active				tdvwport.setCamera( cam );			}		}	}}
  • SasqwachSasqwach Posts: 25
    edited January 2017
    You Sir, are a hero!
    That works perfectly I can bind to a shortcut and have my own icon for quick flipping now !
    Many, Many Thanks !
    PS Are there any other good daz scripting resources / texts other than the API guide ? It's quite cumbersome to work thru
  • Have you looked at Rob's samples? They are release under the CC Attribution Unported license. http://docs.daz3d.com/doku.php/public/software/dazstudio/4/referenceguide/scripting/api_reference/samples/start
  • Thanks I had a look at that area already; was more the actual API docs I found to be a bit tricky to find what I was looking for - Guess it's time to study !
  • bluejauntebluejaunte Posts: 2,255
    Is there a way to switch viewport to one of the view cameras like "Perspective View"? Couldn't find out how to do that.
