Why does Character spin around when i make key frame animation?
I'm really bothered by this. Say from frame 0 to frame 50 i make a little change in the pose. What happens? Sure the change happens but from 0 to 50 the character spins around. I don't get it. why?   Why is it spinning around when i didn't rotate the body
  • Check if the hip doesn't have negative rotation on of the frames. Usually switching from 0.00 to -0.00 usually causes the spin.
  • nokoteb99nokoteb99 Posts: 943
    Oh i see. well in this case( there are other cases but i'll tell you about this one). all i did was from fram A to frame B I moved the hip slightly using the Acitve Tool pose while feet were pinnined.
  • XoechZXoechZ Posts: 1,102
    Are you using a Genesis 3 figure? If yes, then forget the Active Pose Tool. It is broken with G3. DAZ knows about this issue, but has not fixed it yet.
    I use Genesis 2
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,822
    load poses holding ctl and use the options presnted.
