Pick a Computer Whiz's Brain
Mods, you can merge this thread with this one if needed.   Didn't want to hijack that thread - http://www.daz3d.com/forums/discussion/comment/1967101/#Comment_1967101
I think that I have a simple question.
My system is an HP Pavilion Windows 7 Home Premium 64 bit that is 8 years old with an NVidia GE Force 9100 card (with total memory 3815).  When I run dxdiag is shows that I'm running display in 32 bit mode.
I want to install the newest NVidia drivers that I can find but it says that the 64 bit version is for the GE FORCE 9100M card.  How do I find out exactly which drivers I should be using?
  • FishtalesFishtales Posts: 6,232
    The 32 bit is the graphics mode not the system mode which will be 64 bit.
    https://en.wikipedia.org/wiki/Color_depth
    Go to the Nvidia site and have it autodetect your card...
    http://www.geforce.com/drivers
    Or use a piece of software like Speccy to tell you exactly what hardware is in your system.
    Laurie
    The newest one for your card is 342...which isn't all that new.
  • NGartplayNGartplay Posts: 3,420
    edited January 2017
    Thank you everyone.  Looks like I have 334.89 version.  I'll try all the suggestions till I find one that works for me.
    Edit - It says that the drivers I have are the most up to date.  This is not good because I have some software that wants newer drivers to run.  Runs but very slowly.  My last hope for this PC was to get better drivers but not going to happen I guess.
    Edit edit - woohoo, got the 342 installed.  Hopefully this helps run my newer softwares.
    Post edited by NGartplay on
    Would never merge threads by 2 completely different people unless it was a total duplicate, Kulays problem is not going to be the same as yours.
    Thanks Chohole
