How can i import my clothing model to wardrobe ?
Hello there im new to daz3d i make some clothing on blender3d but any way to import my model to daz3d wardrobe thanks for advice
For which figure? If it's a Genesis, File>Import (making sure you use the right preset, so it lines up correctly with the zeroed figure as loaded), then use the Transfer Utility (Edit>Figure>Transfer Utility) setting the Genesis figure as the source and your clothing item as the target. That should give you a basic rig, though you may well need to refine it using the Node Weight Paint Brush tool (and Geometry editor) and creating morphs to correct for additional issue
Thank you Richard
