any way to smooth the wrinkles in the body
I have the following rendered sample. Is there any way to smooth the wrinkles in the body? e.g. the ribs, some bones showi
  • I don't see a picture.  Did you try to upload an attachment?  A picture would really help show what kind of wrinkles you are talking about.  To attach an image click on the Attach a file under the text box and then click on browse to find the file on your computer.
  • Sorry, the picture was probably removed as it did not follow the guidelines here http://www.daz3d.com/forums/discussion/3279/acceptable-ways-of-handling-nudity#latest
  • try to attach. Seems no issue based on the guideline.
    593 x 316 - 17K
    What figure and which morph?
    It almost appears as if morphs were doubling up and producing excessive deformation.
  • V4.2 + pretty base IV injection
  • ValandarValandar Posts: 1,418
    The only way to "smooth wrinkles in a morph" is to create a totally new morph that does that.
  • hphoenixhphoenix Posts: 1,335
    Looks like a single point light render.  You're seeing polygon shading artifacts, not wrinkles.....
    Try using several separated lights (at lower intensity) to soften the shading a bit.  Or up the SubD on the figure to smooth out the surfaces.  Or both.
    Also, try using a shader/material setting that isn't quite so glossy.
    If that's just a screen-grab of the OpenGL window.....then that's not that unusual, nor should it look that way when you actually render the image (if your material settings are correct.)
