[SOLVED]Transfer K4 textures to V4
nicsttnicstt Posts: 11,715
edited January 2017 in Daz Studio Discussion
I noticed I have some K4 textures, any way to transfer them to V4?
Post edited by nicstt on
    Sickleyield has a tutorial on how to use the Map Transfer Utility in her DA account...it could be used (I believe Genesis has both the K4 and V4 UVs included) to do it.
  • pwiecekpwiecek Posts: 1,598
    Texture Converter 2 will do it if the DS native method won't work.
    http://www.daz3d.com/texture-convertor-2-tc2
  • nicsttnicstt Posts: 11,715
    edited January 2017
    Thanks, never thought to check genesis. :)
    I've transfered them on G2 and G3 so presume they are the same, but isn't there only one template on Genesis and earlier?
    EDIT
    NM, 6 templates seems to work.
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,769
    since they all have the same vertex count, you can also give V4, M4, K4 each other's UV with an obj import in the surface tab corner.
