My 3Delight is not rendering even after 15 mins!!
Saphirewild
I do not know wth is going on with my 3Delight rending. I have tried for the past 3 days to render a scene and it will not even start to render even after 15 mins of waiting (my time not daz's)
Can someone help me with this issue?
And has it happened to anyone else?
Using Daz Studio 4.9
Let it go...if it hasn't errored out, then it's going to eventually render. Another regular forum member calls that 'face plant time' and he has had times between 45 min to over an hour! So depending on the content and shaders (AoA SSS can take a very long time before the first pixel shows up).
WOW really I don't have that kinda time though to wait!!!
Like I mentioned, the slow down is likely due to AoA's shader...and if you have multiple characters using it, make sure that each has a unique ID (SSS Group ID...I can't check at the moment, but it's something like that), because if they are all the same, that makes it take even longer. Swapping to a different shader (omnifreaker UberSurface or US2) will speed it up, too.
Thanks for the advice MJC!!
I will try what you suggested and let you know how it turned out.
Well thanks for the advice once again MJC!!! It is finally rendering after I did what you told me to do (I used Omni Uber Base Shader on everything in the scene)
