LIE Baker Glitches...
I purchased LIE baker over the holiday and I have found two glitches that need attention.
1.) WIth Skin builder, you have the option to change makeup color.  This is very useful.  I created two versions of the same character, one with makeup and one without.  When I baked the one with makeup, it worked fine.  Then when I tried to bake the oine without makeup, the LIE Baker kept taking the lipstick from the with makeup back and putting it over the top of the character without makeup?  I even changed the filename and it still happened.  How does LIE know that I am referring to the same character when I change the file name (Even though I was not)?  Each skin builder setting was on a completely different .duf.
2.) When you change the first option pahway, LIE baker stops writing the files that go in the background.  You have to restart DAZ and/or reinstall to get it writing the files again.  (Not sure which, I did both.)
Please fix these bugs (if they are in fact bugs.).
-DrDrk
  • vwranglervwrangler Posts: 5,055
    You need to submit a ticket for this to Technical Support. The person who created LIE Baker died recently, and nobody else here will be able to do whatever is needed. Daz will need to take over for the PA to provide whatever support for her solo products may be needed.
  • Very sad news.  I will do that.
    -DrDrk
