Can't find the morphs++ files for Victoria 4.2
tradivorotradivoro Posts: 74
edited December 2016 in The Commons
Hi there.  So the morph++ files are installed.  I know because the power loader brings them up every time I load V4.2.  However, when I look in poses, all I see is a bunch of useless animations.  Anyway to have the morphs++ show up?  Or are they somewhere else?  I have by context check so I figure it would only show the content for v4.  Is this just a case that things went to the wrong directory and the files have to be moved??  Any info appreciated, thanks.
P.S.  I just checked Michael 4.2 and he is completely fine.  You can easily see his poses, by function and by region, shaping shows his facial expressions and utilities has the useless animations.
Veronica 4.2 on the other hand, in the poses tabs by function and by region has useless animations, with no pictures. Utilities shows no facial expressions.
Post edited by tradivoro on
  • 3Diva3Diva Posts: 12,058
    I'm not sure if there is another place to find them, but one of the places you should be able to find it is your Products category. If you look under Products >> V >> Victoria 4.2 Morphs ++ -you should be able to see the morphs. That's for Daz Studio, mind you. If you're using Poser I don't know, as I don't have Poser, sadly.
    Post edited by 3Diva on
  • NGartplayNGartplay Posts: 3,418
    The Poser route is Pose/Daz's Victoria 4/Morph Injections/Morphs++
    Is it possible that Daz Studio's route is similar?  Look inside content/runtime/......
    Post edited by NGartplay on
  • Thank you both.  I'm using in Daz Studio.  divamkeup, I'll look under that products category.  Ngartplay, thanks for that info, eventually I'll be installing this in Poser as well.
  • After doing a "scan known directories for files" and doing a refresh and loading the program various times, it finally showed up.  Thank you all for all you help.
    Note that you don't need to do this, just point Poser at the Runtime folder in your D|S content location.
  • Thanks.
