Measure Metrics Problem
Hello,
not used MM for a while.
When I load the script I get "This script requires that Measure Metrics plugin be installed & registered to continue".
I have looked at the DIM, type in "metrics" and under Installed there is "Measure Metrics for DS 4.9+ there is no tick to show installed, not sure if that is a problem.
How can I fix this.
Thanks
Are you running the beta?
The tick is for metadata (entries in the Content Management System). Measue Metrics doesn't have user-facing files so there's nothing to need metadata (the scripts and poses are Figure Metrics, a separate package). Most likely you haven't entered your serial number in Help>About Installed Plug-ins, assumng the installed version of Measure metrics matches the version of DS you are using.
Thanks, I will look at the serial number issue when tomorrow.
