Can't find Baroque Grand and Millenium Cat
unknownmystery445unknownmystery445 Posts: 414
edited December 2016 in The Commons
Hi guys, do you know which folders I can find in my daz 3D library content library in Daz the Baroque Grand products and the Millenium cat bundle? I can only find the add ons of baroque but not the whole preset scenes. I can only find like the specific parts of it with the add ons like the ceiling, chair, egc and when I click it says I need to select a scene so I'm guessing there's a preset whole complete scene already that I have to click. I can't also find the Millenium cat bundle in the animals section.
Post edited by unknownmystery445 on
    They might be in the Poser content libraries. I'm almost certain the cat is anyway. Baroque is likely there too since it's the right age ;).
    Laurie
  • NorthOf45NorthOf45 Posts: 5,896
    Baroque Grandeur has D|S native versions of everything. If you are using Install Manager, search for "Baroque". If you have all the parts, you should see "Baroque Grandeur", "Celebrations for Baroque Grandeur" and " Extravagance for Baroque Grandeur" and maybe a couple other add-ons. Right click on one and select "Show Installed Files". The popup list will give the path (on disk and in the library) to each piece. There are a lot of preloads for different groups and promo scenes. All of the elements are labeled with tags like set, material(s), prop, etc. They're all under Environments/Architecture/BAR_G*/...
    Millennium Cat is in the Poser content section, Figures/DAZ Animals, then you need poses (a few included in Pose/DAZ's Mil Cat, just to confuse you) and materials, like Classic Cats.  Poser library entries for Figures are in the Character folder on disk. I think that's the only one with a differnt name.
    I do see the bar_g but when I click it it says I need to select a scene. Even after selecting the character nothing shows up when I click it.
    Do you have the Baroque Grandeur for Iray? All of the stuff loads from a file in the Daz content folder. I rearrange my folders, but looking inside the zip file for the set, it looks like the props are Environments\Architecture\Bar_Gran_v2\Scenes. There are all kinds of preloads there. This is in the NON Iray zip file just in case you don't have the Iray files.
    Laurie
    Laurie
    I do have the iray version. I've looked at the environments though but alright I'll try again later.
    Look for the files that have "Pre" or "Preload" in the title. Those are usually the props.
    Laurie
  • 3Diva3Diva Posts: 12,058
    An easy way to find your content is to go to your Content Libary tab and your Products list and it will show your products icons. If you hover over the icon of the file you're looking for it will tell you where it's found. You can also right-click on the file icon and pick "Browse to File Location" and that will also show you where the content is located. :)
    Laurie
    Uh-h, the Iray version is not a standalone product, only new textures and a couple of additional props. The new Iray scene files expect the original to be installed for it to work. The original has items in these folders (and not any deeper)
    Environments/Architecture/Bar_Gran_v2/Materials (24 items)
    Environments/Architecture/Bar_Gran_v2/Scenes (38 items)
    The Iray version adds an Iray subfolder to each one with all the Iray materials and scenes.
