Need Help with DSON - writable Poser directory mapped
Dead_ReckoningDead_Reckoning Posts: 63
edited December 2012 in Daz Studio Discussion
I have been able to create the needed "duf" files to use with DSON
My problem starts when I attempt to "Run the Action to Create the Files" - Poser Files cr2/pp2 etc and python file
The Guide says to"
In order to convert files for use by the DSON Importer, you must be in the “DAZ Studio Formats” directory. For the files to save out in the Poser file format, you must have a writable Poser directory mapped for the product as well.
I have installed everything to the Default Locations
I just haven't been able to create the cr2 and py files needed.
I can copy a cr2 and py file from another DSON compatible and edit/rename and get the new "duf' to work.
Thanks
Post edited by Dead_Reckoning on
  • fixmypcmikefixmypcmike Posts: 19,738
    What OS and what's the exact path?
  • Dead_ReckoningDead_Reckoning Posts: 63
    I am using WINVista HomePremium x64
    Apparently it is working, I just need to sort out the output paths
    I found this:
    Genesis Starter Essentials Poser\Runtime\libraries\props\DSON Conversions\People\Genesis\props
    It created a Runtime within theOEM Rruntime
    Here is how it is presently set up
    Destination (Poser Formats)
    Base Path
    C:/User/DR/Documents/DAZ3D/Studio//My Library
    Relative Path
    /Runtime/Libraries
    Use the library and File Extension props - pp2
    Supplemental Path
    /DSON Conversions
    copy relative source path(2) - Not Checked
    I have to figure out the oyutput paths
