How do I create a movementslider for multiple nodes?
You all know that we can select more than one node (collar->shoulder->forearm for example) by ctrl-clicking them and then select "all" in the parameters tab and use the bendslider on all selected nodes wich sometimes creates smooth movement. Is it possible to create one new slider out of the selected nodes wich controls them (something like a master-slider)? It´s really annoying to ctrl-click all the nodes again and again when tweaking your pose/animation.
Thanks in advance!
Yes, this what the Pose Controls on the figure node are. You can make you own by setting multiple bends as you want when the new control is at 1, then
that should give a control that will adjust multiple bends - if it works use File>Save as>Support Assets>Morph Asset to save it for use on all figures of that type.
