Fastest Iray Shaders to Render?
I assume that some Iray shaders render faster than others. When rendering indoor scenes using old poser format rooms and furniture, would there be a simple Iray shader to apply to them that would help speed up the render? If I don't care about super photo real backround/rooms, is there a shader/material I could apply to the 3Delight surfaces that would help with long render times?
Any advice would be cool to here. Anything to help with long Iray renders, right? Thanks
  • Oso3DOso3D Posts: 15,110
    The Iray Uber shader mutates to fit the settings. That is, if you don't use Translucency, the Translucency bricks (code blocks) are absent when the shader is sent to the engine (as far as I can figure out -- if you send your surface to the shader mixer, you will note that the bricks depend on what settings are active).
    So, the fastest would simply be: use only the basic stuff (base color, glossy) and that's it.
  • sarge74sarge74 Posts: 121
    Thanks William. Appreciate the input.
    So does anyone have an Uber Shader Preset they find is the most basic/fastest to render?
    edited December 2016
    Not really. Your best bet is just to avoid emissive, reflective, refractive and translucent or transparent surfaces. IOW, stick to duller, more diffuse surfaces ;).
    Laurie
    Post edited by AllenArt on
    Note that with reflection default allows near infinite path of reflections. You can get great results dropping path (in render settings) as low as 5. Much below that and you can get weird 'black' shading in reflective/transparent stuff.
    Normally it's set to -1, which is 'unlimited.'
  • nonesuch00nonesuch00 Posts: 18,856
    I got iRay renders to render orders of magnitude faster by locking Shutter Speed & F/Stop and dialing down Exposure Value to 1.0 at UHD resolution. You the have to adjust the brightness in Gimp or Photoshop and scale the image down to FHD or HD resolution.
