How can I tell what hair will work with Iray renders (on V4)
Actually, this may apply to more than just hair.  Is there a way to tell whether hair, clothes, props or scenes will render well with Iray, before buying them?
  • As supplied most, if not all, Victoria 4 is not going to have Iray materials. However, that won't necessarily stop you from using them - though I would suggest investing in UHT 2 and some Iray fabric shaders that you like the look of.
  • Another factor is how much time you're willing to put into adjusting the materials. Changing everything into proper Iray format using the Iray Uber Base shader is only a beginning — the automatic conversion is pretty good, but not perfect, so many parameters will need tweaking.
