Unable to get the DAY-SEVEN-BONUS to work
First of all, for the daily freebies at Daz. Thanks!  I also think you are getting me to buy quite a few items that way too ;-)  However, today your DAY-SEVEN-BONUS gives me an invalid coupon code when I try and use it. Not sure if it is just me or everyone.  Hope you can fix it so I can complete my order.
Keith
    Hmm..worked for me just awhile ago :( Are you sure there isn't an extra space in the code that sneaked in? That would make it invalid.
    Laurie
    edited December 2016
    Check that you have no leading or trailing spcaes in the Copupon code.  Make sure that the case is right when typing the coupon code.  Make sure that you only have the relevant items in the cart,  Some other items can stop the bonus coupon codes working,  so one new item and 8 free items,  or just 7 free items with no new item,  nothing else in the cart.
    Post edited by Chohole on
    But it worked for me even with other stuff in the cart o.O
    It seems the problems arise with new items that are free being in the cart or with putting an item in that is one of the bonus items and not realizing it is in that catagory; so that you have too many bonus items.
  • The code is correct. I could try no other items, but I doubt Daz would want people to eject the pay items to get it to work ;-)
    Have you tried it with only the qualifying items?   and then do another order for the rest
  • TaozTaoz Posts: 10,346
    Works fine here, both with 7 items and 8 + a NEW item. Doesn't matter if code is upper or lower case it seems.
    But they should really add that Trim function, that's all it takes to make it ignore spaces before or after the discount code.
    Post edited by Taoz on
  • Roman_K2Roman_K2 Posts: 1,277
    FWIW, worked ok at 3:35 EDT approx.  7 free items + some poses for G2F $5 approx.
  • Removed items. Applied the coupon with only the freebies and it worked. Then added new release and other items
