Carnite's tutorial and the Shader Mixer with DAZ 4.9
How come this tutorial:
​No longer seems to work right? I'm guessing it has to do with something between RSL and MDL, which I *think* are the difference between 3Delight and IRAY?
​When I open up Preview above a box and click in it to do a test render, the screen doesn't update, and it doesn't apply in my aux viewport the way it does in the video.
​I also tried:
https://www.daz3d.com/shader-mixer-tutorial-i
​And had the same kind of results. I was following along step by step, but what the presenter was saying and doing wasn't matching up with my experience.
  • Is your render engine set to 3Delight?
  • No. Nvidia. Is that what I need to do? Set the "draw options" to 3Delight for the aux and main viewport?
    ​So, these tutorials really only teach how to set up 3Delight shaders? Maybe that is where I am confused... when I buy shader packages, they show up in 3Delight, but they also work when I render an image using IRAY... is there some missing component in understanding how to mix a shader that will work in both?
    I'm really doing this to get a better understanding of shaders and how they work... I really have no idea... obviously. :D
    I just know that they seem useful.
  • prixatprixat Posts: 1,618
    Yes, all the older information you find will most likely be for 3Delight, that's all there was back then.
