Black tongue and palate problem
Hello everyone,
I used 'Michael 5 Elite Skin Texture Dave' for Michael 5. But on the rendered image, the tongue and palate are all black (see attachment). I tried to solve this but that didn't work out. Any ideas to solve this problem?
Any help would be appreciated!
Best regards, Rudy
520 x 296 - 22K
Iray render? If you select teh tongue surface in the Surfaces pane (from the list in the Editor tab or by clicking on it with the Surface Selection tool) which shader is it using - that will be listed at top-left of the Surfaces pane in the Editor tab.
Hi, thanks for your reaction. Yes, Iray render. And the shader is: omUberSurface.
When I use Render mode Interactive then the tongue is black, when I use Render mode Photoreal then the tongue is red. See attachment.
I thought uberSurface was usually converting to Iray OK - I wonder if it uses some unusual values. Unfortunately I don't have that set to try it out.
Unfortunately, that's abacadabra for me. I'm in Daz3d for 2 weeks now.
If no one comes along with a suggestion of a chnage to make I think you need to open a support ticket for Technical Support: http://www.daz3d.com/help/help-contact-us
Thanks Richard. I'll do that.
