How to make a realistically-sized visible sun in Iray?
A while ago I tried positioning the sun so that it would be visible in the background of a scene, but no matter what adjustments I made, it was always a blinding large white area with no visible 'sun'. Does anyone know the settings so that a small but bright sun can be made visible in an Iray scene? Thanks in advance.
  • zaz777zaz777 Posts: 115
    Did you try "SS Sun Disk Scale" in the Environment category of Render Settings ?
    I couldn't see any difference until I bumped up the EV a notch in Tone Mapping.
  • SnowSultanSnowSultan Posts: 3,832
    edited December 2016
    I did try the sun disk scale but I'm not sure I adjusted the Tone Mapping while doing those tests. I'll give that a try.
    edit: Raising the exposure value to 16 made it visible. Thanks.
    Post edited by SnowSultan on
  • Oso3DOso3D Posts: 15,116
    Another approach is to lower the environment strength to about .5
  • RafmerRafmer Posts: 564
    Turning the Burn Highlights per Component OFF and lowering the Burn Highlights value also helps.
