Installing Daz files to Poser
VolcanicMinkVolcanicMink Posts: 0
Q1) When I try to load V4 (Base) or M4 (Base) in Poser 8 it says it can't find the file and makes me go look for it. M4 doesn't actually show up; the menu bar says he's there, but the stage is empty.
How do I load these so they will work properly and load directly from the menu?
Q2) I found a forum question about the new installers. Poser 9 to Poser 12 apparently use DSON Core and Poser CF. What about Poser8? Do the files find these installers on their own or will I have to direct them?
Using PC.
    edited December 2012
    If a product is packed for DSON and Poser 9+ then the chances are it will not work in Poser 8
    Products that will work with Poser 8 will either have a Poser core installer, or a .DPC.
    When you installed V4 and M4 in poser, where did you install them., and did you initialise them
    Post edited by Chohole on
  • Richard HaseltineRichard Haseltine Posts: 111,859
    When installing V4 and M4 choose DAZ Studio as the target application - it doesn't change the files installed, but it does skip the check for the Poser application file. When the figures were released, Poser 6 was current and for that they had to be in the application folder's Runtime, but with modern versions of Poser that is unneeded and with current operating systems it's a bad idea.
  • VolcanicMinkVolcanicMink Posts: 0
    These were helpful. Thank you!
