Solved - Character with Anorexia?
Kevlar31
I added in a character and it loaded normally, this character is based off Teen Josie 7, however, when I add another character based off Teen Josie or Teen Josie herself the first character turns into an anorexic copy of herself. Pictures below first is char by herself, second it Teen Josie left and char right. Any ideas?
320 x 320 - 18K
320 x 320 - 32K
Post edited by Kevlar31 on
I some experimenting on the exact same scenario with G3F and there was no change to the character. However, I tried the same thing with some characters out of a package called Josie's friends and there was no change when I added one of the chars. I added another one from the Josies friends package and the first one's face and scale changed (even though the scale was locked. Now these two, it turns out, don't need Josie just G3F morphs. So it appears that when I load two chars with the same base the first one loaded changes when I load the second. Weird. I will do some more experimenting and post later.
Some how the morph is doubling up...and if you are loading a separate character/new G3F, it shouldn't be doing that...
If you make sure that the first character is not selected, in the Scene tab (click on a light or something) does this happen?
Do you get a popup asking if you want to load a new 'base'?
What do you get when you dial the original morph out of the first one loaded?
It looks like you hit the nail on the head. If I have a character selected it occurs when the new char is loaded. If I don't have anything selected they load fine and the other char stays as it was.
Yes I am getting the popup with the option for new base which I have selected each time.
Thanks so much mjc1016!
