Importing more than one object on Zbrush?
Helloo, I have a little trouble concerning the use of Daz and Zbrush ; I am still quite noobish with the technicalities.
When creating a morph on Zbrush for a piece of clothe like a shirt, I often find myself in need of my gen3 model to see if it fits correclty or if there's still some poke through. Basically I'd like to work on a clothe while having the model on the zbrush scene. Thing is, I don't know how to import 2 figures/object on zbrush from DS. I think it is called a polygroup on Zbrush.. I know it is quite easy to manage that with GoZ, but this GoZ doesnt work for some reason. I'm using morph loader pro.
Where should I start? Also, is the exporting back to Daz will be different?
Thanks fo ya time m8
If the shirt, or whatever, is fitted and aprented to the figure both should go to ZBrush (as sub-tools) - if not select each in turn and hit the Send to ZBrush command in DS. You then modify the shirt, make sure the figure in DS is selected, and with the shirt sub-tool active click GoZ in Zbrush to send it back.
I can't make GoZ works... Can I do it the same way with morph loader pro?
Yes, the return from GoZ is pretty much giving an alternative UI to Moprh Loader Pro as far as I know - it just skips the fiel selection and scale/axis specification.
Got it. Thx for the hint Richard.
