Weightbrush won't erase
ghastlycomic
I'm trying to erase a weight brush but when I hold down alt and paint it barely seems to do anything. Does the erase function have a separate intensity setting from the paint brush?
Hi...
The sensitivity slider works for both adding and subtracting weight...
Sometimes I find that when I go to remove some weight, nothing seems to happen when I hold Alt and paint over the weight... what I found that seems to work for me is to hold Ctrl, paint over the area a bit, and then go back to Alt and the weights then remove....
I think it's a bug with the weight brush (4.5.1.6), because it doesn't always happen when trying to remove weight...
I'm still running though tests in the latest Beta, so I don't know if this still occurs or not...
nicci... :)
Thanks, I'll try that.
