SOLVED - UberEnvironment 2 - No light/black render
alextherusalextherus Posts: 14
Hello guys. I'm having a problem when using UberEnvironment 2. I load the "!UberEnvironment2 Base" item as described by the tutorial into the scene but when I render, the scene is light-less. I tried changing the "intensity scale" parameter but nothing changed.
Do I have to set special rendering parameters to allow this to work or set other lights?
(i'm leaving an attached picture of a white cube rendered with uberenvironment light)
Thank you in advance.
640 x 480 - 21K
Post edited by alextherus on
    Which renderer are you using?
  • ToborTobor Posts: 2,300
    Which rendering engine are you using? UberEnvironment is for 3Delight. Daz Studio defaults to Iray. Iray doesn't use UberEnvironment lights.
  • Oh. That's what it was. Thank you!
    Is there something similar for Iray?
    Iray has all the functions of UberEnvironment built-in.  All you need to do is make sure that Dome or Dome and Scene is set in the Environment settings in the Render Settings tab.  And then insert a HDRI image in the Environment Map.  But that should be the defaults...Dome and Scene, with a loaded HDRI.
