Import Daz's Camera FBX into Unreal Engine 4.
What I want to do is take advantage of UE4 amazing particle system and add them to my Daz animations.
I figured out how to import Genesis and its animations but I can do the same with Camera FBX data.
I tried to do it via Matinee but each time I choose the FBX file to import I get no response from software.
Also worth noting the camera is animated by attaching it to a null object which then makes a 360 turn over 2 seconds with 30 FPS.
Did tried again by importing Camera's animation alone by unparenting it from the null and deleting it. Same effect.
  • ArtiniArtini Posts: 11,014
    edited December 2016
    Is it not better to create the camera movement in Unreal Engine 4 directly, instead of exporting it from Daz Studio.
    I do not use Unreal Engine 4, but Unity 3D and there are a lot of add-ons in their asset store to animate camera.
    Just a thought...
    Post edited by Artini on
  • ArtisanSArtisanS Posts: 210
    If you attach the camere to a null object and animate it with the null object, shouldn't you be exporting the FBX file of the null object? Just a thought!
  • TryhardTryhard Posts: 166
    Yeah that did turn out like that.
    I did managed to export the camera eventually by just putting in parameters but it completely mixes up the Axis's upon arrival in UE4. Adleast that's how it looks when I try doing it through Mitalee.
    Im gonna try doing it with Sequencer and see if it's any different.
    Post edited by Tryhard on
    Just a thought...
    The reason I want to do this is because I want to tak advantage of UE4 gorgeous particle system.
    What I want to do is load assets and camera into UE4.
    Make them all transparent on black background.
    Render a sequence of particles on a black background.
    Render the same sequence in Daz.
    Take both renders and layer them together.
    Enjoy Daz3D animation with gorgeous UE4 particle effects.
