DIM not connecting?
I can get to "my account", but DIM itself returns "unable to login to the specified account" etc after evrything is checked as correct an a full restart done to the system.
  • Ditto. Same thing happening to me for over an hour now. angry
  • idem pour moi aussi,  aussi bien sous DIM que sur DAZ Studio 4.9
  • I am having the same issue. and now.. i cant even connect in daz3d. servers? :(
  • I concur.
  • rono64rono64 Posts: 58
    Same problem, this is getting to be a regular problem, happens at least once a week now.
  • dennis.d.t2972686dennis.d.t2972686 Posts: 81
    edited December 2016
    same here
    Post edited by dennis.d.t2972686 on
  • ScytharScythar Posts: 127
    same here
  • Every time I try to log in as soon as i press connect the whole system freezes HELP!!
    This has been reported.
    DAZ Access within DAZ Studio does work though,
    So, technically, you don't need DIM...
    gr. Patrick
  • Same.  Poor Monique wants to get into my inventory and is quite frustrated.  (._. )
  • NorthOf45NorthOf45 Posts: 5,896
    PC+ status is not working either. Doesn't recognize me as a member, so none of the benefits are available.
    You are not showing as a PC member - if you should be please open a support ticket.
    gr. Patrick
    Not everything can be installed through Connect, however, though the Monique 7 content all can as far as I know.
    Direct downloads from the product Library page also seem to be working, so it's possible to download the zips and place them in the DIM Downloads folder to be installed.
    In any event, as Chohole says this has been reported by a couple of routes so with luck it will be fixed fairly quickly.
    This is getting to be a common event, new release, buy it, then wait hours and hours to install and use it.
    Getting tired of this pattern.
  • SimonJMSimonJM Posts: 6,100
    Woohoo, first time for me for this happening! cheeky
    Done.
  • same here
  • And it's back! \o/
  • Woo Hoo!!! Downloading now.
    Jason
  • Cool that it is working for some now. Tried today and Dim is not working for me.
  • serapine68serapine68 Posts: 15
    The DIM don´t work for me. I have this Problem since Yesterday.
    Post edited by serapine68 on
  • namffuaknamffuak Posts: 4,513
    And its failing again - 16:44 EST
    Network Error during authentication.
    Unable to login customer during authentication.
    Saving Account Settings: Account
  • Failing again over here too.  17:55 EST
    Should be fixed now
  • The downloading is still extremly instabile with DIM. Really often I need a second try in the last days, because  the down load rate went down to 0 byte and stopped with download failed
