Moving to actual script forum....
athenenoctuaathenenoctua Posts: 0
yep.
Post edited by athenenoctua on
  • TugpsxTugpsx Posts: 918
    If you have QT interface then you are 80% there. Wasn't there a QT builder included in the DS SDK or DAZ Pro distribution..
    The sliders can be linked to dz functions to get studio to react to them.
  • athenenoctuaathenenoctua Posts: 0
    Hi and thanks for your reply.
    I used the Qt Builder included in Daz Studio 4.5 to make the interface.
    I'm not sure what code to put in the header to enable the widget to remain undocked and overlain on the active viewport.
    Maybe I'll try some test lines and post them here.
    edited December 2012
    post moved
    Post moved. I have no idea how to delete this box.
    post moved
    Here is a simple slider script.
    // DAZ Studio version 3.1  filetype DAZ Script
    var wDlg = new DzDialog;
    var box = new DzVGroupBox(wDlg);
    box.width=300
    box.height=200
    var w = new DzEnumSlider( box )
    w.addItem( "oh" )
    w.addItem( "my" )
    w.addItem( "Bob" )
    w.value = 2;
    // setup button to update debug results
    but = new DzPushButton( box );
    but.text = "debug";
    connect( but, "clicked()", butclicked )// click button to show update in debug
    wDlg.width=300
    wDlg.height=200
    wDlg.exec()
    function butclicked()
     debug( "val = " + w.value );
    BTW if this project is mostly script based it should be in the Script forum.
    if you want to call an external script from within be sure to set return point also.
    Ooo! Bless you.
    This isn't the script forum?
    Ok, I'll look for it.
    Thanks again.
