New Runtime(s)
I'm completely starting over.
So I'll have Gen1, 2, 3 and Poser.
Is there a reason(s) I just don't want to make 1 oganized (organised for Dson portion & Poser) Runtime with everything in it?
Thank you
  • LeanaLeana Posts: 13,473
    The main reason I see to use multiple Runtimes is to separate the content you have into smaller libraries, so you can choose to load only some of them if you don't need the others.
    That can be pretty useful when you have tons of content ;)
    It can also be useful to separate non-commercial freebies from the rest of your content if you make commercial work.
  • dracorndracorn Posts: 2,377
    I'd like to know how you separate out your runtime, especially if you use DIM. Do you have to uninstall and then reinstall? I have extensive categories and want to preserve them.
    If content is already installed then yes, I would uninstall and reinstall.
  • SixDsSixDs Posts: 2,384
    Unless something has changed more recently, the advice that has always been given by the DAZ folks is not to create too many content libraries. Although the CMS database can handle more than one, I suspect that the problem lies in the resource overhead involved in having the database keep track of multiple repositories, but I am simply guessing at that.
  • Geoffrey_WoodgetGeoffrey_Woodget Posts: 98
    edited December 2016
    Support recommended using only one to me.
    You people were my 2nd opinion(s). :)
    Post edited by Geoffrey_Woodget on
