HeadShop One Click Installation Problem
I have installed this usuing the manual download and then unzipping the file and selecting the 64 bit install file. Everything goes fine. Checking the plugins installed shows the HeadShop plugin where it should be. All of the other files seem to be where they are supposed to be.
When I start the program, it tells me to select and call up a figure with a head bone, which I do. Then I select the texture and geometry from the menu, and it immediately says it cannot find the FaceShop plugin, end terminates.
What file(s) is missing from what directory?  I can navigate directories to try and locate the problem, but would like a little help here as to what I am looking for.
Thank you
