Can't get Tears HD Plentiful Tears to work properly
Hello,
whenever I add these tears http://www.daz3d.com/tears-hd-plentiful-tears to a character the eye itself just gets watery, no real tears.
The Resolution Level is already set to High Resolution, same for the Render SubD Level (Minimum) is already set to 2.
Nevermind, typed "plentiful" in the Parameters Pane and found the morphs, silly me... But my other question still remains.
Also, how can I remove the watery eyes without pressing Ctrl+Z, haven't found their entry anywhere. :o
I'd appreciate the help!
Best regards.
  • You may need to reapply the original material preset.
  • BinkzBinkz Posts: 43
    Unfortunately that doesn't seem to work. Guess I have to reload the character then?
  • I meant the material preset for the character you are using - if you are using the figure in its default state there should still be a preset.
    Oh ok, that did work, thanks. But when applying any other eye the effect comes back, weird.
  • alex86firealex86fire Posts: 1,130
    Sorry for opening this up again, I was wondering if there is any way to get them to work for G8 models.
  • LeanaLeana Posts: 13,617
    Those are HD morphs, you can't transfer them to G8. Well, you can probably transfer a base res version but I doubt the result would be good.
