Editing Items in the Scripts Menu?
Stryder87
in The Commons
I know where you go to change their order and remove them if you want, but is there a way to edit the text on them? I'd like to modify some of them to be more descriptive and there isn't any obvious way to do this.
Window>Workspace>Customise...
The entries from the Scripts menu, plus other things, will be under Custom in the action list on the left - find yours, right-click on it, and select Edit Custom Action... - you can edit the Menu text (the actual words from the menu) and the Description (which appears in the status bar when your mouse is over the command in a menu, or in a pop-up if it's on a toolbar).
Ahhhhhh.... that's why I couldn't get it to work. I was navigating to it on the right side.
Thanks Richard!
