Genesis 2 to 3 pose converter by dragon storm
How do you use this product.  I can't find any instuctions.  Have never run a script.  Please HELP!
  • Is this the same product?  It says its for animations.
    regards
    Nat
  • BeeMKayBeeMKay Posts: 7,019
    edited November 2016
    http://docs.daz3d.com/lib/exe/fetch.php/public/read_me/index/22122/22122_pose-converter-user-instructions.pdf
    You'll also find the manual in your ReadMe Folder:
     /ReadMe's/22122_Pose-Converter-User-Instructions.pdf
    Though I have to admit that it's not very much of a documentation.
    The sales page has an image that is a bit more speaking.
    Basically, you first have to select a folder where you want to save your converted poses. Then, you select the folder that contains the poses you want to convert (the folder where its installed, not whatever is in smart content; drag and drop won't work), and then, you click on "Convert files", and it will save the converted files in the the folder you specified.
    Example: you want to convert these poses:
    http://www.daz3d.com/celestial-poses-for-genesis-2-female-s
    You'll have to select the folder where it's saved, for example, you'd select
    THISISYOURPATH/People/Genesis 2 Female/Poses/Celestial Poses/
    1643 x 859 - 170K
    Post edited by BeeMKay on
  • Thanks.  Is there a way you can convert all your poses at once or does each folder have to be converted one at a time?
  • Also HOW DO YOU RUN THE SCRIPT?  This product needs step by step instructions
    Please note this thread
    http://www.daz3d.com/forums/discussion/134596/draagonstorm/p1
  • Well there is always a reason. My heartfelt condolences.  I didn't realize that  Scripts are normally run from - Daz Studio Formats - My Library - Scripts
  • Steven-VSteven-V Posts: 727
    Each folder has to be done one at a time I believe.  It does subfolders, but... since the new DAZ Connect folder structure is by product item now, I am not sure if that will work at a higher level than a single pose set.
    Also I am not sure you'd want it to. Doing it one folder at a time will let you organize things in your My Library folder.
