How can I set a expression morph to the default?
After using several expression morphs I want to set the face to the default morph and I don't know how. I tried to set all the morphs to zero from "currently used" but it still has morphs on it. The expression packs I have doesn't have a "Zero morph" What I should do?
Thanks for the advice! laugh
    Which figure...if it's a Genesis 3, figure not all the expressions will be morphs, some will be poses and you may have to zero the entire figure...try the Zero Pose option from the Parameters tab.
  • It's annoying when it does that. I just pick the head and got to Edit/Figure/Restore/Restore Selected Item. I have to repose the head but that's a small price considering.
  • I have to zerro the entire figure sad but anyways it helps a lot
    Thanks for all the answers!
  • No just the head. The rest of the figure pose and the morphs remain unchanged.
  • nonesuch00nonesuch00 Posts: 18,897
    Wow, that sounds like it would work for the hands too. I just spent 30 minutes yesterday straightening out all the fingers on a hand.
