Reptilian 6 loads without morphs after I save a file
When I save a file with the Reptilian 6 file and reopen it, all the morphs are lost. What can I do to fix this? Installed via DIM. 4.9 public build.
1920 x 1080 - 208K
Well, if I lock the morphs when I first load the figure then it reloads just fine. That is so weird.
Are there any errors in the log file after loading - Help>Troubleshooting>View Log?
Not that I can see.
Does the moprh still work if you manually redial it?
No, the only fix I could find was locking the morph value when I first load it. After that it will continue to load with the morph.
