SimTenero Shape Reprojector help
Super cheese sandwich
in New Users
Hi all. I own the SimTenero Shape Reprojector but it's difficult for me to "play" with it because it takes like 2 hours to make a morph. How can I replicate the effect of the image attached? What setting I have to tweak?
Thanks!
1000 x 1300 - 219K
First, you need a model with enough polygons - the tool can't add resolution and works with the base cage even for SubD items. I would imagine that image used a very high polygon plane.
Hi Super Cheese! Richard is exactly right. I used a super high poly plane for that image, I think 100 sub-divisions or something crazy like that :-). Each figure was a separate morph pass with pre and post smoothing. I've managed to get the best results by using separate smoothing morphs and then playing around with the dials to get the effect I want. More iterations isn't always better, so start low and only dial up if you aren't seeing the detail you need (and remember to try separating out the smoothers and dialing them back later to see some detail return).
Thanks Richard and SimTenero!!! I did it!
Not with that quality but I did it
