Can not see free content loaded into DS 4.9 (64bit) (Win 10 OS)
Tried to load a freebie from Share GC.  It is Ghastly's Natural Niples for Gen 2  I loaded it in the "My Librariy" folder in the content library but it does not show up when I click on the My Library icon in the Content Library.  The folder structure of the download is My Library/data/DAZ 3D/Genesis/Female/Morphs/Ghastly/Natural Nipples/Natural Nipples.dsf.  Question is "Where do I ut this thing?"  I alreadu tried to oload it in the Data file on the Daz 3D public library and that did not work either.  TIA
BTW, I haven't played witrh Daz 3D since the 2.3.3 days so I am statting all over .  I do have a lot of V4 content but was planning on staying mainly with G2 & G3 for now.
    The morph will appear in the Parameters pane, there's no user-facing file.
  • The morph will appear in the Parameters pane, there's no user-facing file.
    DOH, thinks, I found it. blush
  • Anything that gets installed into the /data/ folder is exactly that — data, not content. It's exactly the same as the standard set of DAZ morphs that you can buy to go with a particular Genesis generation, they don't add items to your content folder, they add parameter dials to the Genesis figure they're made for.
    Note that there is an exception to this; character morphs. If you buy a character, there are usually content items that turn the character morph on or off. In every case, there will also be parameter dials so you can dial in only a part of the morph (you won't always want every morph either 0% completely off or 100% completely on with nothing in between).
