DIM and Connect
I thought that DIM wasn't suppose to show the products that were installed by Connect...if you have it set right. Either I misunderstood, or I don't have it set right. Both Connect Available and Connect Installed are NOT checked, but they all still show.
  • nicsttnicstt Posts: 11,715
    They'll show as far as I know.
    I use Dim, and don't have the SQL components installed (to completely disable Connect and DRM), so no way of knowing if what you're seeing is normal.
  • Whera re you looking? The filters you are using affect only the Ready to Download tab.
  • Kev914Kev914 Posts: 1,135
    That's where I was looking. I was going to do a screen shot, but it appears that it is working now. All the new items listed are for Poser, and I didn't install any of those.
    Earlier, it was showing Lucian 7 and other recent products that I bought. I did check those two options to see if I was understanding it backwards. But nothing changed, with them checked or unchecked. But maybe I didn't wait long enough for it to update. Still...they weren't checked when I opened DIM and I think that means that Connect items shouldn't show.
    Anyhow, it is working now.
  • fixmypcmikefixmypcmike Posts: 19,718
    Items should show if they match ANY tags.  You can use filters on those tags, but unticking them doesn't hide items that fit other tags.
    OK. Thanks. Didn't think of that. That makes sense.
