Can clothing be morphed after being fitted?
Hello!
I am trying to create the illusion of a too small bikini top on a Genesys 2 Female. I've tried several ways. I fitted the bikini top on the Genesys 2 figure but found no way to make it small again in order to create the illusion that the bikini is too small for her frame. I've also tried puting the bikini on manually but found no way to somehow morph or deform the bikini top to make it look like it's streching... I'm new to the Daz 3-D artform but am a quick learner! :)
Any help or ideas will be greatly appreciated!
  • Yes, you can morph after fitting - you could take it into a modelling application and then import the morph with Morph Loader Pro with Reverse Deformations set to on to strip out the pose and any morphs applied, or you could use DForms inside DS.
  • gederixgederix Posts: 392
    You could try the fit control product for G2 females.
    http://www.daz3d.com/fit-control-for-genesis-and-genesis-2-female-s
    Basically you dress your figure then select her and run the script, which will add numerous morphs to whatever fitted items she is wearing, which will then all you to adjust the clothing. The issue I see is making it look like the too small suit is digging into her skin.
