How do I edit and see the coordinates of an object?
How do I edit and see the coordinates of an object? Thanks.
With the item selected look at the parametrs pane - it should be open by default, but Window>Panes(Tabs)>Parameters if not. The Transforms group has the translation, scale and rotation settings as long as the thing you have selected is an independent item (for the bone of a figure you won't usually see translation values).
