Illumination options
SonofbelmontSonofbelmont Posts: 147
edited December 2012 in Carrara Discussion
Hi
In Daz studio 4 you can change a individual lights illumination to diffuse only or specular only, how do you do this in Carrara?
any help would be appreciated
thanks
Post edited by Sonofbelmont on
  • 3DAGE3DAGE Posts: 3,321
    There is no such thing a specular light and /or diffuse light in the real world
    these are properties of the object / material and its Highlight and Shininess strengths or maps.
    if you want objects glossy or dull in a specific areas you can create a grey-scale image and add it to the shininess
    hope it helps :)
    You can't. Carrara's specularity is controlled in the shader of the object, not the light. This is a fundamental difference in Poser/DS and most of the rest of the 3D world...
    If you have PRO you can render out separate Multi-Pass layers for Diffuse and Specularity.
    HDRI / Image-based Lighting (IBL) creates non-directional light without specularity. (any of the Global Illumination options on their own generally do not create specularity, I believe)
    You can control specularity in each shader. It is a 2-channel control the first called HIGHLIGHT which controls the color and pattern and uses the UV map (if you have a specular map put it here).... The second channel is called SHININESS and it is a single value (best controlled with a VALUE 0-100 shader) that focuses the specularity according to the angle of the light. Lower numbers spread the specularity across the object, higher values focus the specularity to a narrow angle.... I have a video tutorial on my website called "Creating Skin Specularity" or similar... Link to my site is in my sig below...
  • araneldonaraneldon Posts: 712
    Shaders Plus appears to have this feature.
  • Kevin SandersonKevin Sanderson Posts: 1,643
    Holly's video tute on specularity is highly recommended along with her other tutes! :)
