another flakey G3M conversion to G2M question
WendyLuvsCatzWendyLuvsCatz Posts: 41,744
edited November 2016 in Daz Studio Discussion
video of what I have so far working in Carrara
What works
I can autofit G3M to G2M and save as support asset and it will work in Carrara
I can add visemes using GenX as the G3M control morphs will not work as use bone riging not there I assume the other morphs do and so do genX visemes
now the bits I need to solve
Mimic needs the viseme morphs on the head
I can in edit mode use property clone and move them
I can drag them to the base of the tree
but it still is not seen by the configuration file
I can save a cr2 in DAZ studio of from a DSON loader import in Poser
I can see and assign the visemes from body not head in the object tree in mimic pro
but the ones in body will not be driven by the exported dmc configuration file in Carrara and it will not see the head ones
they are visible under head in Poser.
why??
I can get a working G3M in Carrara that will wear G2M clothes
is all I have, as G3M will crash Carrara
so work around as best I can
what I want help with
someone who actually knows how morphs work in regard to mimic to give some suggestions and imput as I have hit a roadblock
heart
oh the shoe feet morph was an accidental addition before anyone asks
I posted this in the D|S section as what needs to be done has to be done in D|S, the result should then work in D|S as a Genesis 2 male with a diferent mesh too so relevent.
444 x 894 - 75K
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,744
    Ok now I am getting somewhere saving the cr2 from DAZ studio instead of Poser after dragging the morphs to head worked in Mimic at least.
    Not in Carrara though ......
