IRay Sun & Sky frustration
nonesuch00
Ok, with a lot of help I finally got my scene set up and rendering but there is one problem.
The scene is iRay rendering Sun & Sky Finite Box without Ground but doesn't really matter if I choose Infinate or Finite or Dome or Box I end up with a band of grey between my scene and the sky of about 1/10 of the height of the render all the way across horizontally.
I want to create the render without the grey band although it could pass for a horizon line of trees in the distances and do so without post work or compositing. Is it possible?
Thanks.
Hi,
for Sun-Sky there is the helpful parameter "Horizon Height".
Set it to small negative values with approximations in 0.1 steps.
And you can play around with the dome radius. - Both in combination.
For HDRI domes please see this thread.
thanks
