Dirtshaders for iray
Hi
I often use the Dirt shaders by stonemason. I find they work great on machinery type things and put the grunge in just the right places. They will not work in iray however and wondered if there is a way to easily get the same effect using that.
Cheers.
  • There's a product designed specifically for Iray http://www.daz3d.com/a-touch-of-dirt-for-iray
    I own it but haven't had much time to use it though so I can't comment more than that.
  • fastbike1fastbike1 Posts: 4,084
    It works. Several options.
    Artbyphil said:
    Hi
    Cheers.
    Are you sure...if they are tiling overlays using the LIE, then they could work.
  • mjc1016 said:
    Artbyphil said:
    Hi
    Cheers.
    Well I have tried it and the dirt dosnt seem to show up in iray. maybe there is a setting I need to change.
  • ArtbyphilArtbyphil Posts: 97
    edited November 2016
    I have looked at that. it seems more for figures though and  puts the dirt everywhere  where as the stonemason one emphasises the edges and  crevices which seems better for machanical type objects.
    http://www.daz3d.com/daz-studio-dirt-shaders
    Post edited by Artbyphil on
  • StonemasonStonemason Posts: 1,271
    if anyone wants to try recreating that dirt shader for Iray....
    the shader I made uses an occlusion node to place dirt into the corners and an inverted occlusion node to add wear and tear to the edges of models,these nodes act as masks that I then use to blend between different texture maps,there's no LIE involved, I also used another texture map mask to add some randomness to the occlusion masks
    good luck
    S
    Post edited by Stonemason on
    good luck
    S
    Thanks...that gives a good starting point.
    good luck
    S
    good luck
    S
    interesting to be honest I've not really done any shader creating as such. someting I should delve into really but I look at it and I'm never sure where to start :)
  • Oso3DOso3D Posts: 15,125
    It's simply an overlay, not 'intelligent,' but I have a bunch of dirt/grime shaders in free thing in my sig.
    And, well, free.
