moving several objects
Is it possible to move several unconnected objects at the same time?
  • LeanaLeana Posts: 13,671
    If you want to move them and keep their related position, the simplest solution in DS is to create a new Null, parent all objects you want to move to it, then move the Null.
  • calaopiecalaopie Posts: 215
    edited November 2016
    It works but it is difficult to precisely set,especially rotation
    Post edited by calaopie on
    it shouldn't be any more difficult than setting the position of any object in your scene. I use this method often.
    As for rotation, obviously you will need to position the null at the centre of the rotation you want (rather than just creating the null at the zero position)
    I did not think about it, thanks for the advice laugh
