Millennium Dog to Iray
So I just bought the Dog and I was wanting to convert it to Iray, How would I go about doing that, I checked the store and didnt find anything that would work?
Manually...
Select the dog, then in the Surface tab, select a surface...apply the Daz Iray Uber base....repeat for the various surfaces. Then tweak. For the Coat surface you'll probably want to up the Subdivision level and apply a map to the Displacement channel (bump map).
Or you can apply the attached material preset and tweak from there...it's set up for the 'basic' red Doberman texture. If you ctl-click when applying it, you can choose Ignore and it will use the texture maps currently in place.
Put the content of the zip file somewhere you can find it...like your Presets folder or a material folder for the dog.
