Scene won't render in IRay
When I try to render, it does about 24 iterations and then the yellow bar appears and goes immediately to 100%. But nothing displays in the window except a checkerbox pattern.
I did try to render in 3 Delight and it did render, but it showed an error NaN in primitive. Does that have anything to do with why it won't render in IRay?
Also...if you turn off things using the eyeball so they are not visible, do they still cound when you render...or do you actually have to delete them to see which one might be the problem.
Thanks.
  • areg5areg5 Posts: 617
    Don't think I understand the question.  Are you rendering through a camera or using perspective view? Outside or in a room?
  • Do other scenes or even a single primitive, render in Iray?
  • BeeMKayBeeMKay Posts: 7,019
    Itay and 3Delight are atotally different render engines, so wha works in one doesn't necessarily work in the other.
    As for the image you are trying to render, a few more information is needed. What is in the scene? Characters? Items? What lights are you using? Do the tems have Iray surfaces, or 3Delight surfaces?
    Have you changed the Iray render settings?
  • Kev914Kev914 Posts: 1,129
    Yes. I opened an older scene to test and it rendered fine. The figure is M3D Reed. Bold hair. Thathe hairy product...can'the recall the name. I converted all the textures to Iray using Daz Uber. There is a back drop which is just a back wall. I added a camera and had it use the scene the way I framed it. I used koury's scintillating lightest. It does change some render settings. I even tried making a smaLloyd adjustment cause that sometimes works if you get a black screen. But this is an empty scene. The window opens. It starts to render but no image fills in. And it finishes in less than a minute. I will create a new scene an and start adding the items one at a time and ssd if it renders. Can't remember what skin texture I used. Not at my computer.
    Well, I created a new scene. I added the same character and a texture and I tried to render and it did, even though I hadn't updated the textures to IRay. Then I added the other items I used and it still would render, so ...I don't know what was wrong with the other file.
    Thanks.
    Sometimes the products have flaws and don't render, or they render really slowly.  Did you look at the log file and see what the issue was?
  • It has to do with temp files. Delete all temp files and render should start normally.
  • HavosHavos Posts: 5,606
    Is your camera just under the floor, or behind a wall? Sometimes this looks fine in the viewport, but will render as black or grey since the floor/wall is blocking the camera.
