Manipulation tool
How do I change the manitulation tool(s) to reflect a new pivot point. Occasionally I find the original mesh has the manipulation tool so far from the item itself I can't see it should I zoom to close up. I know how to do this in Poser but Studio eludes me.
  • The Joint Editor tool can be used to move the centre point - but that should be used with care, and if the item is a figure rather than a prop the first thing to check is that it hasn't been moved using the bone at the base of the hierarchy isntead of using the figure node itself.
  • cclesuecclesue Posts: 420
    Is Hair considered a prop?
  • fixmypcmikefixmypcmike Posts: 19,709
    In th4e Scene pane does it show a single block or multiple blocks?
    "does it show a single block or multiple blocks"
    Not sure what you mean
  • FistyFisty Posts: 3,416
    The little picture next to the name in the scene tab..  single cube for a prop, 3 little cubes stacked for a figure (and the little arrow to open up the bone tree is a good indicator too.)
