suggest usefull button toollbar action
cm152335cm152335 Posts: 421
edited November 2016 in Daz Studio Discussion
Hi all,
i am amateur user on Daz3D and i want to suggest usefull toolbar button for "poses"
most of the time i am lookin for a "REVERSE POSE"
 not all creator use reverse poses and when they use reverse poses they need to flood the library with lot of icons,
a permenent button (REVERSE POSE) coulf be useful if it stay always in interface "toolbar"
also some most used action for user like "RESET TO ZERO" button, dedicated to the "SELECTED" area
examples, "RESET FOOT"  - 'RESET EXPRESSIONS"
anyway, what i mean is  to added some most needs button on toolbar, so poses creators no need to create obsolete repeated poses or reset,
in my Daz Library i estimate more than 300 same icons "RESET" are found and most of them are not work for all
Post edited by cm152335 on
  • Go under the Parameters tab menu:  Zero options are there for pose or shape or for the entire figure.  The "Reverse Pose" function is "Swap Y and Z Axis" or something, under "Symmetry" and its shortcut is CTRL + Y.
  • I thought the Symmetry command was already on a toolbar, if not you can add it. Got to Window>Workspace>Customise. On the right open the Toolbars tab and find the toolbar you want to add the command to. On the left Symmetry should be under Parameters, drag it from there into the Tool bar.
    The default shortcut for Symmetry if Shift Y
  • Ah, thanks, Mr. Haseltine!  CTRL+Y is "Redo" if anything.
  • ConnaticConnatic Posts: 287
    Exactly what combination of all the settings must I choose to get a simple result of mirroring a figure's pose?  In Poser it is quite simple to do, but the same procedure in Studio is overly-complex.  I have tried many combinations and have never gotten it to work.
  • fixmypcmikefixmypcmike Posts: 19,710
    Nodes: Root
    Propagation: Recursive
    Direction: Swap Left and Right
    Trunk Nodes: Mirror Across Y Axis
    Nodes: Root
    Thank you!  It spins the figure around, but otherwise does the mirroring.  No problem reorienting the rotation.
  • cm152335cm152335 Posts: 421
    i know about the menu;
    as example key, for "FACE expressions" i select the "head" and press CTRL+E (restore selected default)
    but depend the use, in some expression (by users) the reset is not helpfull because some user added "shape" to expressions
    also for eyes; in some case i must select the "eyes" and manualy input "0" on X,Y position!, more hard for "TOES"
    for mirror i found a script who reverse totaly the pose and custon action >> to the toolbar
    and thank's for your input.
