Installing non-Daz items into DS 4.9
It has been a long time since I loaded anything not made by DAZ.
I recently bought an item at Rendenosity which is made for G2F, the Centigrade suit made by Out of touch..
This has to be unzipped and loaded into DS manually. Install Manager installs items to C:/ Users/..... /My DAZ 3D Library. so I guess I put the files for Centigrade suite there also. I do encounter a problem though, because when I unzip and install the files the computer tells me that there is a   "File expansion Conflict" and do I want to Skip File, Replace file, or Cancel.
What should I do in a case like this?
Thanks
    It means you are installing to the correct place as tehre are folders already there with the same name.  7zip, freeware, does not give that message for folders, only files.
  • Thanks.
    So do I chose Skip File, Replace file, or Cancel. when I get that message showing up?.
  • Oh..... it does not show up in the Products area for DS 4.9.
  • SPACECHIMPSPACECHIMP Posts: 212
    edited November 2016
    Hi Bending grass I have this product it is in the daz content library under  My daz content/people/genesis 2 female/clothing/oot centigrade.Choose skip file.
    Post edited by SPACECHIMP on
  • ErdehelErdehel Posts: 387
    You get that message because every product sold at rendo contains a documentation folder with their EULA. You can safely skip or overwrite this folder/file when asked. I usually choose overwrite because this documentation folder also contains the documentation for the product if available.
  • Thanks Spacechimp and Erdehel.
    That is a great help also. I should make notes on this stuff.
    Randy
